AttributeError: 'int' object
Postby wls-canada » Fri Jun 29, 2018 10:01 am
Using latest (2018-06-28) git sources for alarmdecoder, alarmdecoder-webapp, and ser2sock, firmware 2.2a.8.
When I try to run the diagnostics I get the following. Any tips where to look closer? I can see the serial_number.upper() call in ad2web/settings/views.py (commit 2 Nov 2016 so not that new), but I am not sure where I should look in the alarmdecoder source to see what might be missing. Unless it's an inherent python function but not in python2.7? I am not a python programmer.
AttributeError: 'int' object has no attribute 'upper'
Traceback (most recent call last)
rv = self.dispatch_request()
File "/usr/local/lib/python2.7/dist-packages/flask_login.py", line 758, in decorated_view
return func(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/decorators.py", line 16, in decorated_function
return f(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/settings/views.py", line 717, in system_diagnostics
device_settings['serial'] = current_app.decoder.device.serial_number.upper()
wls-canada
Re: AttributeError: 'int' object
Postby wls-canada » Fri Jun 29, 2018 10:10 am
Hmmn. Strings can have an upper() but not ints. serial_number has been around for a long while in decoder.py... so I have opened an issue at the git. Has nobody else tried to run diagnostics after setup in the last two years or so?
wls-canada
Postby jasonsf » Fri Jun 29, 2018 7:21 pm
If you pulled latest from the command line and not through the web app, you might need to run python setup.py install from the AlarmDecoder folder to install the latest version. I was having similar issues.
Sent from my Pixel 2 using Tapatalk
jasonsf
