virtual serial port competition?
Postby bupkes » Fri May 02, 2014 12:27 pm
Newbie here ...
I successfully connected my ad2usb to my Vista 20p and my Mac Mini running OSX 10.8.5 I had the GUI registering and reporting alarm states properly. (FWIW I did not get 2way enabled because I was unable to program the ad2usb to address 17 .. mostly because I indvertently locked out my installer code by not RTFM correctly).
Anyhow .. I then tried to hook up my Indigo system .. which again worked properly. However when I went back to the GUI it never got past the waiting for communications. I also tried to install a Z-wave HA interface which also failed. I assume the issue is the single FTDI virtual serial stuff. How do I make this work?
Also could not install the panel programming module for the GUI .. I couldn't find a modules folder just the app itself.
Thanks in advance
bupkes
Re: virtual serial port competition?
Postby mathewss » Fri May 02, 2014 1:12 pm
Sounds like it would be easier if I talk on the phone too many variables in what you are saying is going on to have a good answer.
Give me a ring at our office phone
http://www.nutech.com/contact.php
