Sep 23 11:22:54 alarmdecoder /usr/sbin/cron[2007]: (CRON) STARTUP (fork ok)
Sep 23 11:22:54 alarmdecoder /usr/sbin/cron[2007]: (CRON) INFO (Running @reboot jobs)
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Found user 'avahi' (UID 103) and group 'avahi' (GID 105).
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Successfully dropped root privileges.
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: avahi-daemon 0.6.31 starting up.
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Successfully called chroot().
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Successfully dropped remaining capabilities.
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Loading service file /services/alarmdecoder.service.
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Loading service file /services/udisks.service.
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: socket() failed: Address family not supported by protocol
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Failed to create IPv6 socket, proceeding in IPv4 only mode
Sep 23 11:22:56 alarmdecoder kernel: [ 29.545067] Adding 102396k swap on /var/swap. Priority:-1 extents:1 across:102396k SSFS
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Network interface enumeration completed.
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Registering HINFO record with values 'ARMV6L'/'LINUX'.
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Server startup complete. Host name is alarmdecoder.local. Local service cookie is 1134205678.
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Service "alarmdecoder" (/services/udisks.service) successfully established.
Sep 23 11:22:56 alarmdecoder avahi-daemon[2078]: Service "alarmdecoder" (/services/alarmdecoder.service) successfully established.
Sep 23 11:22:57 alarmdecoder ntpd[2121]: ntpd 4.2.6p5@1.2349-o Fri Jul 22 22:29:05 UTC 2016 (1)
Sep 23 11:22:57 alarmdecoder dhcpcd[1870]: eth0: leased 192.168.1.211 for 86400 seconds
Sep 23 11:22:57 alarmdecoder avahi-daemon[2078]: Joining mDNS multicast group on interface eth0.IPv4 with address 192.168.1.211.
Sep 23 11:22:57 alarmdecoder avahi-daemon[2078]: New relevant interface eth0.IPv4 for mDNS.
Sep 23 11:22:57 alarmdecoder avahi-daemon[2078]: Registering new address record for 192.168.1.211 on eth0.IPv4.
Sep 23 11:22:57 alarmdecoder ntpd[2122]: proto: precision = 1.000 usec
Sep 23 11:22:57 alarmdecoder ntpd[2122]: Listen and drop on 0 v4wildcard 0.0.0.0 UDP 123
Sep 23 11:22:57 alarmdecoder ntpd[2122]: Listen normally on 1 lo 127.0.0.1 UDP 123
Sep 23 11:22:57 alarmdecoder ntpd[2122]: Listen normally on 2 eth0 192.168.1.211 UDP 123
Sep 23 11:22:57 alarmdecoder ntpd[2122]: peers refreshed
Sep 23 11:22:57 alarmdecoder ntpd[2122]: Listening on routing socket on fd #19 for interface updates
Sep 23 11:22:57 alarmdecoder dhcpcd[1870]: eth0: adding route to 192.168.1.0/24
Sep 23 11:22:57 alarmdecoder dhcpcd[1870]: eth0: adding default route via 192.168.1.1
Sep 23 11:22:57 alarmdecoder ntpd[2122]: restrict: error in address '::' on line 38. Ignoring...
Sep 23 11:22:57 alarmdecoder ntpd[2122]: restrict: error in address '::1' on line 42. Ignoring...
Sep 23 11:22:58 alarmdecoder dhcpcd[1870]: forked to background, child pid 2190
Sep 23 11:22:59 alarmdecoder ser2sock[2213]: [✔] Using config file: /etc/ser2sock/ser2sock.conf
Sep 23 11:22:59 alarmdecoder ser2sock[2213]: [✔] Serial 2 Socket Relay version V1.5.2 starting
Sep 23 11:22:59 alarmdecoder ser2sock[2213]: [✔] Listening socket created on port 10010
Sep 23 11:22:59 alarmdecoder ser2sock[2213]: [✔] daemonizing the process
Sep 23 11:22:59 alarmdecoder ser2sock[2216]: [✔] Using PID file: /tmp/ser2sock.pid
Sep 23 11:22:59 alarmdecoder ser2sock[2216]: [✔] Seting thread priority to HIGH
Sep 23 11:22:59 alarmdecoder ser2sock[2216]: [✔] Start wait loop using raw communication mode
Sep 23 11:22:59 alarmdecoder ser2sock[2216]: [✔] Opened com port at /dev/ttyUSB0
Sep 23 11:22:59 alarmdecoder ser2sock[2216]: [✔] Setting speed 115200
Sep 23 11:22:59 alarmdecoder ser2sock[2216]: [✔] Set speed successful
Sep 23 11:23:00 alarmdecoder sm-mta[2261]: My unqualified host name (alarmdecoder) unknown; sleeping for retry
Sep 23 11:23:02 alarmdecoder sm-msp-queue[2298]: My unqualified host name (alarmdecoder) unknown; sleeping for retry
Sep 23 11:24:37 alarmdecoder sm-mta[2261]: unable to qualify my own domain name (alarmdecoder) -- using short name
Sep 23 11:24:37 alarmdecoder sm-mta[2301]: starting daemon (8.14.4): SMTP+queueing@00:10:00
Sep 23 11:24:39 alarmdecoder sm-msp-queue[2298]: unable to qualify my own domain name (alarmdecoder) -- using short name
Sep 23 11:26:45 alarmdecoder ser2sock[2216]: [✔] Socket connected slot 2
Users browsing this forum: No registered users and 16 guests
