Compatibility with Vista 4140XMPT2
Postby lexam » Fri Sep 15, 2017 7:42 am
Hi all,
I need a definitive answer as to if the AD2USB (or other product from Alarm Decoder) is compatible with my alarm panel, the Ademco Vista 4140XMPT2.
Thank you in advance
lexam
Re: Compatibility with Vista 4140XMPT2
Postby kevin » Fri Sep 15, 2017 9:34 am
If your panel supports alpha displays it will likely work on address 31 - these are old panels, and a lot of them do not support alpha - if they don't, it will not work with your panel
Postby lexam » Sat Sep 16, 2017 1:22 am
It does support alpha displays, as all of my displays are alpha-type. Is there any way I can test for compatibility before ordering? I saw in the alarm's manual that it supports a master display, at address 31, which would have control over all 8 partitions. Does that help?
Sent from my iPhone using Tapatalk
lexam
Postby kevin » Sat Sep 16, 2017 10:19 pm
It certainly meets all the criteria to work... sounds just like SE panels that are supported - I'd say give it a shot. If it doesn't work, send it back and we'll refund you.
Postby lexam » Fri Oct 13, 2017 1:45 am
just in case someone is looking for an answer on this, I just received my AD2USB and it works (almost) fine with my Vista 4140XMPT2. I get all the signalling and can issue commands fine.
Cheers
lexam
