Repeating Messages, Ignoring Keypresses
Postby richharms » Sat Feb 04, 2017 8:30 pm
I have a Vista 20P, and a Raspberry Pi 3 with the AD2PI board on it. The Pi is using the image available on this site. The system was originally installed by a security company, but I have the installer code for it. I've enabled keypad 18 on it for the AD2PI, 16 doesn't exist, 17 is the one that they installed for use by me (verified the address set up on it). I could use some help interpreting this behavior.
There's two things I'm noticing, the first is when I'm testing it with the web app on the Pi, and the system is armed, the message displayed on the web app's keypad jumps between two different messages. I can see this happening if I telnet into the ser2socket port:
[10000001000000003A--],008,[f70000060008001c08020000000000],"****DISARMED**** Ready to Arm "
[00100001000000003A--],008,[f70000011008008c08020000000000],"ARMED ***STAY*** "
And it just keeps bouncing between the two. The actual physical keypad on the system shows it's armed.
The second issue, is if I send keypresses from the web app, or directly from the ser2socket connection, they appear to be ignored. Here's an example of trying to disarm the system:
[10010001000000003A--],008,[f70000060008001c08020000000000],"****DISARMED**** Ready to Arm "
!Sending.done
!Sending.done
!Sending.done
!Sending.done
!Sending.done
[10010101000000003A--],008,[f70000020008011c08020000000000],"****DISARMED**** Ready to Arm "
[10010001000000003A--],008,[f70000040008001c08020000000000],"****DISARMED**** Ready to Arm "
I noticed keypads 16 & 17 get separate messages watching this, whereas they're normally combined. Attempts to arm it do not arm it.
"Test Device" under diagnostics passes everything, the "Sending.done" appears to be succeeding, so I'm not sure where to look for the problem at this point.
Rich
richharms
Re: Repeating Messages, Ignoring Keypresses
Postby kevin » Sat Feb 04, 2017 11:29 pm
There appears to be 2 different partitions.
Address mask 00000600 is address 18 and 19
Address mask 00000110 is address 17
So I am not sure what this would do with regard to arming and disarming on a 2nd partition that isn't really configured... your keypad at 17 certainly wouldn't see these messages and do anything with them
Our device seems working as intended - it appears your programming is off
Postby richharms » Sun Feb 05, 2017 6:29 am
Thanks, I was suspecting partitions, but wasn't sure - I figured the AD2PI was working perfectly. I'll talk with the company that did the bulk of the installation.
Rich
richharms
Users browsing this forum: No registered users and 2 guests
