Webapp not sending key presses
Postby satch80 » Sat Jan 28, 2017 1:48 pm
I've somehow messed up my Webapp install during an upgrade. Everything seems to be working fine except I can't use the Webapp to send keypresses to the alarm panel. The diagnostic communications work fine (both send and receive).
I'm running on a Rpi using a AD2USB device.
After attempting to send keypresses I get the following traceback. Any help would be appreciated.
File "/opt/alarmdecoder-webapp/ad2web/app.py", line 95, in __call__
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1473, in full_dispatch_request
rv = self.preprocess_request()
File "/usr/local/lib/python2.7/dist-packages/flask/app.py", line 1666, in preprocess_request
rv = func()
File "/opt/alarmdecoder-webapp/ad2web/socketioflaskdebug/debugger.py", line 36, in protected_method
return f(*args, **kwargs)
File "/opt/alarmdecoder-webapp/ad2web/decoder.py", line 635, in on_keypress
self._alarmdecoder.device.send(key)
File "/opt/alarmdecoder/alarmdecoder/decoder.py", line 253, in send
self._device.write(data)
File "/opt/alarmdecoder/alarmdecoder/devices.py", line 803, in write
File "/usr/local/lib/python2.7/dist-packages/serial/serialposix.py", line 518, in write
d = to_bytes(data)
File "/usr/local/lib/python2.7/dist-packages/serial/serialutil.py", line 63, in to_bytes
raise TypeError('unicode strings are not supported, please encode to bytes: {!r}'.format(seq))
TypeError: unicode strings are not supported, please encode to bytes: u'1'
satch80
Re: Webapp not sending key presses
Postby Scott » Mon Jan 30, 2017 11:20 am
I think this is actually a bug on our end. Sorry about that! I'll try and get a bugfix release out today or tomorrow.
Postby David.B » Tue Jan 31, 2017 6:27 pm
Same issue here...
David.B
Postby David.B » Tue Jan 31, 2017 6:51 pm
Until official update; I changed the serial write to send as string... it fixes the issue.
file: /opt/alarmdecoder/alarmdecoder/devices.py
Line 803:
self._device.write(data) change to self._device.write(str(data))
Code as fixed below...
def write(self, data):
        Writes data to the device.
        :param data: data to write
        :type data: string
        :raises: py:class:`~alarmdecoder.util.CommError`
        try:
        except serial.SerialTimeoutException:
            pass
        except serial.SerialException as err:
            raise CommError('Error writing to device.', err)
        else:
            self.on_write(data=data)
David.B
Postby Scott » Wed Feb 01, 2017 11:33 am
New bugfix release pushed up. Should take care of this issue.
Thanks for the suggestion David. Ended up being a little more complicated since we're trying to support both Python 2 and 3 in the library itself. Just a note, you should revert your changes prior to updating as it will cause the updater to fail.
Postby satch80 » Wed Feb 01, 2017 4:16 pm
Very nice. That's working perfectly now.
Thanks for the fast fix!
satch80
