AD2PI zone events log in UTC time instead of local timezone
Postby m_listed » Sun Jan 22, 2017 1:08 pm
I set my Raspberry Pi's time zone to my local zone, and this seems to be working for the "App" and "Live" logs, but for the "Events" log, the AD2PI app continues to log every event according to UTC time instead of local time. How can I make it so these events are logged per local time as well?
m_listed
Re: AD2PI zone events log in UTC time instead of local timez
Postby kevin » Sun Jan 22, 2017 2:01 pm
Login via ssh and set your date/time, we ship it as UTC by default - https://www.cyberciti.biz/faq/howto-set ... nd-prompt/
The python event stores the current date/time in the database and on rendering the datatable it is passed through a javascript function to normalize to your localtime - so I would check that date/time parameters are set correctly. I suggest the timedatectl method
Event log timestamps are converted using the following function:
        function RenderDateLocal(oObj)
            //parse date from python to format Date object understands
            var match = oObj.aData[oObj.iDataColumn].match(/^(\d+)-(\d+)-(\d+) (\d+)\:(\d+)\:(\d+)$/);
            var localDate = new Date(match[1], match[2] - 1, match[3], match[4], match[5], match[6]);
            //take care of timezone offset in minutes to hours by negating and then adding to the hours
            var tzo = (localDate.getTimezoneOffset()/60) *-1;
            localDate.setHours(localDate.getHours() + tzo );
            //reformat date for consistency
            var dateStr = localDate.getFullYear() + "-" + (localDate.getMonth() + 1) + "-" + localDate.getDate() + " " + localDate.toLocaleTimeString();
            return dateStr;
Postby m_listed » Sun Jan 22, 2017 6:17 pm
I don't think JavaScript has a central place where the timezone is set, but timedatectl nevertheless shows the correct local time and UTC time because I did "sudo dpkg-reconfigure tzdata" and set it to my local timezone. The Alarmdecoder web app still shows all zone fault and restore etc. events as UTC though. It was working correctly (i.e. logging in local time) before the latest update though.
m_listed
Postby kevin » Sun Jan 22, 2017 10:56 pm
All right, please file an issue on the github project and it'll be added to the list of things to investigate/fix on another release.
The JavaScript above uses your local clientside computer's time data to calculate based off of time/date from event in datatable
Postby billfor » Wed Mar 01, 2017 5:09 pm
Looks like fnRender is ignored if used, so the RenderDataLocal never gets called. fnrender has been deprecated from jQuery so you have to use mRender going forward.
The "Live" section never had the problem because the code doesn't actually pull the value from a database -- it just stamps it with your currently time. So there is no transformation there.
Do you want me to file a bug?
fyi if you want to fix it temporarily, find the events.html file and change this line:
{"fnRender": RenderDateLocal },
to
{"mRender": RenderDateLocal },
now because mRender works differently, you also have to change the rendering function.
change
to
function RenderDateLocal(data,type,full)
and change the first line that has the regex matching to:
var match = data.match(/^(\d+)-(\d+)-(\d+) (\d+)\:(\d+)\:(\d+)$/);
billfor
Postby kevin » Thu Mar 02, 2017 10:21 am
billfor wrote:Looks like fnRender is ignored if used, so the RenderDataLocal never gets called. fnrender has been deprecated from jQuery so you have to use mRender going forward.
to
change
to
Looks like we stumbled upon this fix around the same time. I did it a little differently. Yes to the mRender step, but did not change prototype of RenderDateLocal at all
            var match = oObj.match(/^(\d+)-(\d+)-(\d+) (\d+)\:(\d+)\:(\d+)$/);
            return dateStr;
At any rate, this was due to an upgrade of the dataTables plugin that we use - and is fixed locally here - hopefully pushed to github sometime soon.
Thanks for your help!
Postby billfor » Thu Mar 02, 2017 10:55 am
Yeah the other arguments are thrown away but technically the definition of mRender calls for a 3 argument function so I just added them as per their spec. It was interesting that the Jquery developers decided to deprecate and nullify an old function rather than just leaving the behavior there for people who had used it. Anyway it works now -- was just annyoing the hell out me so had to fix it :-)
billfor
