Can't Get Output in Python Program
Postby Rene » Mon Jan 09, 2017 12:42 am
I am trying to intercept arm/disarm messages from my A2PI so I can execute http post to enable/disable my cameras. I ready that I should use Ser2Sock calls because the /dev/ttyAMA0 port is already used by the web app but can use whatever method works. I have used python sample code to try and connect to the SocketDevice and read the output messages. I am running python right on the A2Pi and also am using SSL. The program runs but not I don't get any output. I tried telnet {IP} 10000 from a remote computer on the same network and it does not receive any messages either. Is the SSL cert preventing output? Not sure what I am doing wrong. However, the web app picks up all alarm panel messages.
import time
from alarmdecoder import AlarmDecoder
from alarmdecoder.devices import SocketDevice
#default AD2Pi device on Raspberry Pi
SERIAL_DEVICE='/dev/ttyAMA0'
BAUDRATE = 115200
SER2SOCK_HOST = 'localhost'
SER2SOCK_PORT = 10000
def main():
Example application that prints messages from the panel to the terminal.
try:
# Retrieved an AD2 device that has been exposed with ser2sock on localhost:10000
device = AlarmDecoder(SocketDevice(interface=(SER2SOCK_HOST,SER2SOCK_PORT)))
# Retrieve the first Serial device
#device = AlarmDecoder(SerialDevice(interface=SERIAL_DEVICE))
# Set up an event handler and open the device
device.on_message += handle_message
print 'Running...'
with device.open(baudrate=BAUDRATE):
while True:
time.sleep(1)
except Exception, ex:
print 'Exception:', ex
def handle_message(sender, message):
Handles message events from the AlarmDecoder.
print sender, message.raw
if __name__ == '__main__':
main()
Rene
Re: Can't Get Output in Python Program
Postby kevin » Mon Jan 09, 2017 12:37 pm
encrypting the ser2sock stream will definitely do this - you have to setup your cert chains to deal with it properly.
That said, if you're using the webapp, it has built-in custom GET/POST based off events in the notifications.
Postby jeffwu » Wed Sep 06, 2017 7:56 pm
I plan to use "Custom" notification in web app to send events info to a REST API server where it compiles the data to determine zone occupancy state. what system variable(s) is available in Custom Notification setting ? (I guess they can be referenced in custom key/value field?) with other built-in notification methods, like pushover, the notification message contains zone id and zone status. how can I construct a custom notification to send similar zone info to my own REST web server.
I use "nc -lv 8080" to print output sent by web app. I didn't see any event info contained in HTTP header or data.
your help is much appreciated.
Jeff
jeffwu
Postby kevin » Wed Sep 06, 2017 8:01 pm
All you need to do to achieve that is customize your messages for the events and use the message replacer - these are replaced in different places and different ways - this way you only have to replace it in your message and it will work across all notifications. The custom notification replacers listed are the ones available.
You can add {arm_mode} to the armed event message to get instant/stay/away status
The key/value pairs are represented via GET or POST and accessible in the request via those methods
example php using GET:
<?php
    echo $_GET['message'];
You will have to parse the message to get the data you want if you want to get that granular.
Postby jeffwu » Thu Sep 07, 2017 6:47 am
Where should have the list of message replacers? Is it within WebApp setting page? I didn't see them or I could overlook.
jeffwu
Postby kevin » Thu Sep 07, 2017 7:41 am
When you create a custom notification and add a key/value pair, a helpful tooltip will appear at the bottom of the notification screen with a list.
If you are looking to customize your notification messages - there is a button on the main notifications page at the bottom for editing your messages. Replacers here aren't listed - the only one missing is {arm_mode} by default installations.
Postby jeffwu » Thu Sep 07, 2017 4:03 pm
thanks Kevin. I didn't notice the tips. now I created a new custom notification and after adding key/value fields, the tips were shown.
I followed the tips and added these key/value pairs
1)key: time, value: {{time}}
2)key: msg, value: {{message}}
with GET method and urlencoded.
however, I could see {{time}} was replaced by actual time values. {{message}} was not replaced. why was that?
below were HTTP headers
GET /ad2pi?msg=%7B%7Bmessage%7D%7D+&time=2017-09-07+19%3A53%3A50+EDT HTTP/1.1
Host: 10.10.0.5:1500
Accept-Encoding: identity
Content-type: application/x-www-form-urlencoded
User-Agent: AlarmDecoder/v1.0
jeffwu
Postby jeffwu » Thu Sep 07, 2017 4:08 pm
nvm. my bad. extra tailing space after {{message}}. it is working now. thanks again.
jeffwu
Postby jeffwu » Sun Sep 10, 2017 6:26 am
Hi Kevin,
you mentioned {arm_mode} missing in default installation, thus I tried to add it in message notification. I amended "Arm" message as below, however, after doing that, I didn't receive "Arm" notification any more. after reverting back to the default, it was working again.
"The alarm system has been armed {arm_mode}." ------ this one didn't work
"The alarm system has been armed." ------ this one worked
Did I miss anything?
thanks
Jeff
jeffwu
Postby kevin » Sun Sep 10, 2017 10:49 am
Ahh sorry it's {arm_type} - as long as you have the latest alarmdecoder library and webapp, arm_type should work
Users browsing this forum: No registered users and 19 guests
