Message into Serial Ad2Pi via Alarmdecoder
Postby maurerdotme » Wed Oct 19, 2016 2:54 pm
How do I sent a message into the AD2Pi via the python alarmdecoder library? I want to pass in the deactivation alarm passcode. I'm looking for some guidance like... use this method to send the message and code xxxx as an argument.
maurerdotme
Re: Message into Serial Ad2Pi via Alarmdecoder
Postby kevin » Thu Oct 20, 2016 9:32 pm
Here is the documentation for the python library which describes exactly what each piece is http://alarmdecoder.readthedocs.io/en/latest/
But it would be something like this
import time
from alarmdecoder import AlarmDecoder
from alarmdecoder.devices import SerialDevice
# Configuration values
SERIAL_DEVICE = '/dev/ttyUSB0'  #change this to your device
BAUDRATE = 115200
def main():
    Example application that opens a serial device and prints messages to the terminal.  Sends 12341 to panel
    try:
        # Retrieve the specified serial device.
        device = AlarmDecoder(SerialDevice(interface=SERIAL_DEVICE))
        # Set up an event handler and open the device
        device.on_message += handle_message
        # Override the default SerialDevice baudrate since we're using a USB device
        # over serial in this example.
        with device.open(baudrate=BAUDRATE):
            while True:
                device.send('12341')   # send 12341 to the alarm panel through the device
                time.sleep(1)
    except Exception, ex:
        print 'Exception:', ex
def handle_message(sender, message):
    Handles message events from the AlarmDecoder.
    print sender, message.raw
if __name__ == '__main__':
main()
Postby maurerdotme » Sat Oct 22, 2016 8:02 am
I had the device.send() in another section of the code. After moving it under the while loop, it worked perfectly. Thanks! :D
maurerdotme
Users browsing this forum: No registered users and 324 guests
