AD2PI with existing Raspberry Pi
Postby jgrant50 » Mon Apr 25, 2016 1:13 pm
I ordered the AD2PI board and installed it on my existing Raspberry Pi 2. I downloaded the pre-built image from Alarm Decoder and wired the board to my Vista 20P panel as keypad address 18. Everything works great - webapp, notifications, etc. I'm now trying to integrate into Smartthings and have run into a bit of an obstacle.
I have followed the GitHub instructions exactly as documented here:
https://github.com/nutechsoftware/alarm ... tree/debug
I am able to add the 2 device handlers as well as the SmartApp with no issues, but when I try to discover the AD2PI device per the instructions, no device is discovered. I've refreshed many times. I've also removed all associated Smartthings elements and started from scratch with the same results.
Has anyone else successfully integrated with Smartthings who can point me in the right direction to troubleshoot?
Thanks in advance.
jgrant50
Re: AD2PI with existing Raspberry Pi
Postby Scott » Mon Apr 25, 2016 1:27 pm
Do you see anything in the SmartThings logs when you're trying to refresh?
First thing I would check is what version of the webapp you're running. You can find that at the bottom of the page. 0.6.2 is current.
If that looks good, maybe a network issue? Are the AD2PI and SmartThings hub on the same router/switch?
Postby jgrant50 » Mon Apr 25, 2016 1:36 pm
Hi. Thanks for the quick reply. I do see activity in the live logging while refreshing, but I'm not sure where to look for the webapp version. I just purchased and installed the board and downloaded the image a few days ago, so I would assume it's at the latest version.
Regarding the network, they are both on the same (192.168.2.x /24).
Thanks again for the help.
jgrant50
Postby jgrant50 » Mon Apr 25, 2016 1:37 pm
My apologies - I found the webapp version (on the web page itself :)
v0.6.2-0-g6558799
jgrant50
Postby jgrant50 » Tue Apr 26, 2016 3:13 am
Any other troubleshooting suggestions?
jgrant50
Postby Scott » Tue Apr 26, 2016 12:02 pm
Could you post the smartthings log from the install/discovery process? Uninstall all of the AlarmDecoder stuff first to make sure there's nothing strange left over.
Postby jgrant50 » Tue Apr 26, 2016 4:26 pm
Scott wrote:Could you post the smartthings log from the install/discovery process? Uninstall all of the AlarmDecoder stuff first to make sure there's nothing strange left over.
I uninstalled all of the components from the IDE early today and just ran the setup again a few moments ago. I'm getting the same results as before. Here is the log entry for the AlarmDecoder (Service Manager):
684a234c-b2dc-438a-a780-52bbd419572f 8:24:20 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:20 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:19 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:17 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:17 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:16 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:16 PM: trace discover_alarmdecoder
684a234c-b2dc-438a-a780-52bbd419572f 8:24:03 PM: trace discover_alarmdecoder
684a234c-b2dc-438a-a780-52bbd419572f 8:24:04 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:04 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:03 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:02 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:02 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpTerm:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:02 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:24:01 PM: trace discover_alarmdecoder
684a234c-b2dc-438a-a780-52bbd419572f 8:23:41 PM: trace discover_alarmdecoder
684a234c-b2dc-438a-a780-52bbd419572f 8:23:41 PM: trace discover_devices: subscribe to location
jgrant50
Postby jgrant50 » Tue Apr 26, 2016 4:38 pm
After it sat for a few more minutes, there are some errors in the log entry:
684a234c-b2dc-438a-a780-52bbd419572f 8:35:52 PM: error java.lang.StringIndexOutOfBoundsException: String index out of range: 154 @ line 125
684a234c-b2dc-438a-a780-52bbd419572f 8:35:52 PM: trace locationHandler: headers=HTTP/1.1 200 OK
Content-Length: 2
684a234c-b2dc-438a-a780-52bbd419572f 8:35:52 PM: trace locationHandler: description=index:17, ip:7F000001, port:23E7, requestId:2944097c-ed50-4007-8b0d-df2988e40ac7, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LUxlbmd0aDogMg==, body:T0s=
684a234c-b2dc-438a-a780-52bbd419572f 8:35:50 PM: trace locationHandler: description=Home
684a234c-b2dc-438a-a780-52bbd419572f 8:35:26 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29::upnp:rootdevice, ssdpTerm:upnp:rootdevice, ssdpNTS:
684a234c-b2dc-438a-a780-52bbd419572f 8:35:26 PM: error java.lang.StringIndexOutOfBoundsException: String index out of range: 154 @ line 125
684a234c-b2dc-438a-a780-52bbd419572f 8:35:26 PM: trace locationHandler: headers=HTTP/1.1 200 OK
Content-Length: 2
684a234c-b2dc-438a-a780-52bbd419572f 8:35:26 PM: trace locationHandler: description=index:17, ip:7F000001, port:23E7, requestId:dea9dcc7-9576-4807-b47e-336cdb4b885c, headers:SFRUUC8xLjEgMjAwIE9LDQpDb250ZW50LUxlbmd0aDogMg==, body:T0s=
684a234c-b2dc-438a-a780-52bbd419572f 8:35:24 PM: trace locationHandler: description=devicetype:04, mac:00178817DB29, networkAddress:C0A80218, deviceAddress:0050, stringCount:04, ssdpPath:/description.xml, ssdpUSN:uuid:2f402f80-da50-11e1-9b23-00178817db29, ssdpTerm:urn:schemas-upnp-org:device:basic:1, ssdpNTS:
jgrant50
Postby Scott » Wed Apr 27, 2016 11:47 am
Hmph. So definitely need a little better error handling in there, but I'm not actually seeing any responses from an AlarmDecoder.
I'll dig up some of my early test scripts for the discovery stuff a little later today so we can test from something other than the AlarmDecoder or SmartThings.
Postby jgrant50 » Wed Apr 27, 2016 12:07 pm
Thanks Scott. Just let me know what you need on my end.
jgrant50
