Python Send Command
Python Send Command
Postby dot850 » Wed Jan 20, 2016 2:38 pm
I am trying to figure out a way to arm the alarm from the python code provided. From looking at the documentation, I find what I think should be device.send() but I get an error back that the object have no attribute 'send.'
Can anybody help? Can I simulate key presses like this to arm the alarm from python?
DOT850
P.S. It is really difficult to search the forums on here because it seems that everything I search for is "common" and is removed. If I get too many hits from searching for common terms that should be my problem, not the forum. Just a thought. :-)
dot850
Re: Python Send Command
Postby kevin » Wed Jan 20, 2016 5:11 pm
Here is a working example of a send while connected to a SocketDevice:
import time
from alarmdecoder import AlarmDecoder
from alarmdecoder.devices import SocketDevice
# Configuration values
HOSTNAME = 'alarmdecoder-demo.local'
PORT = 10000
def main():
    Example application that opens a device that has been exposed to the network
    with ser2sock or similar serial-to-IP software.
    try:
        # Retrieve an AD2 device that has been exposed with ser2sock on localhost:10000.
        device = AlarmDecoder(SocketDevice(interface=(HOSTNAME, PORT)))
        # Set up an event handler and open the device
        device.on_message += handle_message
        with device.open():
            device.send('12343')
            time.sleep(5)
            device.send('12341')
            while True:
                time.sleep(1)
    except Exception, ex:
        print 'Exception:', ex
def handle_message(sender, message):
    Handles message events from the AlarmDecoder.
    print sender, message.raw
if __name__ == '__main__':
    main()
Have adjusted search to remove "Common Words" filtering all together.
Postby dot850 » Thu Jan 21, 2016 4:45 am
Thanks Kevin. You guys are awesome. Are there more examples like this posted somewhere I am missing. I have the examples that came with the python package, did I miss this example somehow?
The next thing I would like to be able to do is see the button presses on the keypad if that is possible?
Thanks so much for all the help.
dot850
Postby kevin » Thu Jan 21, 2016 10:36 am
Sorry, I modified an existing example for that, you did not miss it.
It is not possible to see what keys are being pressed.
Users browsing this forum: No registered users and 20 guests
