Add/Remove Users
Add/Remove Users
Postby aselby » Mon Apr 20, 2015 5:44 am
I was looking at the alarmdecoder on git ... and I'm thinking about buying an AD2PI ... I have a vista 128BP and I want a better way to add and remove users then walking about to the keypad and typing a whole mess of codes in. The installer put everything in compass but they want to charge me everytime I change something so thats not going to work.
I've tried messing with the home automation stuff but its not consistent with typing all the those codes in a virtual keypad over a serial connection.
So I'm wondering if the this AD2PI will solve my problem, I want to be able to enter a new code some where and a "USER POSITION" and have it type all the keys in making sure that it works ...
*it would be great if it would work when it was armed to.
So is there a function in these things for that ?
aselby
Re: Add/Remove Users
Postby kevin » Mon Apr 20, 2015 9:09 am
Sorry, there is no automated alarm programming through the alarmdecoder interface
Postby aselby » Wed Apr 06, 2016 4:06 pm
Is this still the case ... I see on the product description that you guys added now "programming your panel"
aselby
Postby kevin » Wed Apr 06, 2016 4:32 pm
Well, we now have support for interfacing with Compass is what that means.
However, we do have something that MIGHT suit you if you have your installer code - in the web interface you can create a 'custom button' that you can send a string of keys to that might facilitate this. https://www.alarmdecoder.com/wiki/index ... om_Buttons
I think if you know python it would be trivial to replicate that functionality for your own needs with the framework we have released (open source library and web application)
* It will never work when armed, it won't allow you to program when armed.
Postby aselby » Thu Jun 28, 2018 5:38 pm
Just checking on this again ...
Is the custom button / script still the only way to do this ?
aselby
Postby kevin » Thu Jun 28, 2018 8:27 pm
You can write a script or use the custom button or the REST API.
Programming automation was never on the roadmap as far as I know, just the ability TO program.
There are many ways to interface with the device to send the keystrokes you want.
Custom Button
Script
REST API
Users browsing this forum: No registered users and 20 guests
