Ad2USB and Vera 3
I'm having a problem connecting my Vera3 to Ad2USB :
I followed the instructions here for UI5
http://code.mios.com/trac/mios_vista-alarm-panel-ad2usb
then i setup the serial port config from here
viewtopic.php?f=3&t=122
after many reboots : still no go !! turned on error messaging and got the following error
LuaInterface::CallFunction_Job device 4 function SAlarmPartition2_AlarmPartition2_RequestQuickArmMode_run failed [string "-- Required Libraries..."]:268: attempt to concatenate local 'armMode' (a nil value) <0x2c60d680>
I'm using a vera 3 with 1.5.622, ad2usb and a Vista 20P panel with 2 keypads. also, I only have 1 partition, howcome its looking for Partition 2 ?
Any help is appreciated.
thank you so much.
thank you so much.
