Outdated raspberry image
Re: Outdated raspberry image
Postby marclennox » Wed Aug 16, 2017 6:35 am
New user here, and I was having similar issues. Turns out I missed the step to disable the serial console. Until I did this, I was getting random behaviour and timeouts.
I'm running with Docker, and all seems good now.
One thing that confused me, is that the device port is always referred to with /dev/ttyAMA0, and that is the default selection when doing the initial webapp setup, however the command to run with docker maps the /dev/ttyS0 port. Is this a typo? Can anyone explain when it should be /dev/ttyS0 and when it should be /dev/ttyAMA0?
marclennox
Postby kevin » Wed Aug 16, 2017 7:25 am
ttyAMA0 is old, legacy, forget it even exists. :) The raspberry pi changed how they did stuff, it used to be ttyAMA0 for the internal serial port on the gpio.
Postby jailbird » Fri Aug 25, 2017 5:08 pm
I just tried this on an updated Raspbian Stretch Lite install (still using Jessie inside the container though). The one gotcha is that apt.dockerproject.org doesn't seem to have a raspbian stretch repo yet, however upstream Debian does and it seems to work. The small changes I made to install.sh were
- Comment-out the code to add the repo, which is these two lines:
sudo apt-key adv --keyserver hkp://p80.pool.sks-keyservers.net:80 --recv-keys 58118E89F3A912897C070ADBF76221572C52609D
echo "deb https://apt.dockerproject.org/repo raspbian-jessie main" | sudo tee /etc/apt/sources.list.d/docker.list
So just comment them out with a # like so:
#sudo apt-key adv --keyserver hkp://p80.pool.sks-keyservers.net:80 --recv-keys 58118E89F3A912897C070ADBF76221572C52609D
#echo "deb https://apt.dockerproject.org/repo raspbian-jessie main" | sudo tee /etc/apt/sources.list.d/docker.list
- The Debian package is named 'docker.io' instead of 'docker-engine', so change:
sudo apt-get install -y --force-yes docker-engine
To:
sudo apt-get install -y --force-yes docker.io
- The docker group is already created now, so you can comment out this line:
sudo groupadd docker
So:
#sudo groupadd docker
The rest seems to be fine!
jailbird
