Need help with webapp update
Re: Need help with webapp update
Postby kevin » Mon Mar 07, 2016 9:53 am
Can you do me a favor and try bypassing nginx by going to port 5000 - http://alarmdecoder.local:5000 and see if the problem persists? There was a new nginx config in the contrib directory and wondering if that is the issue.
Postby pyrodex » Mon Mar 07, 2016 9:55 am
kevin wrote:Can you do me a favor and try bypassing nginx by going to port 5000 - http://alarmdecoder.local:5000 and see if the problem persists? There was a new nginx config in the contrib directory and wondering if that is the issue.
Done. I get the following:
Forbidden Page
It looks like this was the result of:
*no permission
pyrodex
Postby JJsLegacy » Mon Mar 07, 2016 9:55 am
Port 5000 indeed works fine for me
http://10.10.10.75:5000/keypad/ - showing correctly
JJsLegacy
Postby pyrodex » Mon Mar 07, 2016 9:58 am
JJsLegacy wrote:Port 5000 indeed works fine for me
Interesting... I get redirected to /setup/test on mine.
pyrodex
Postby kevin » Mon Mar 07, 2016 9:59 am
Ok, try replacing the nginx config from /opt/alarmdecoder-webapp/contrib/nginx/alarmdecoder and replace the /etc/nginx/sites-available/alarmdecoder with that (sudo cp /opt/alarmdecoder-webapp/contrib/nginx/alarmdecoder /etc/nginx/sites-available/alarmdecoder && sudo /etc/init.d/nginx restart)
If you clicked on setup and it didn't register as going through the process fully, then this is common.
Postby JJsLegacy » Mon Mar 07, 2016 10:13 am
Ran:
Tried website - no change still stuck at loading.
Tried rebooting just to be sure - still stuck at loading.
JJsLegacy
Postby kevin » Mon Mar 07, 2016 10:14 am
Well, give us some time to reproduce this and see if we can get a fix out - until then you can bypass nginx by going to port 5000 to use the keypad on non-working devices
Postby kevin » Mon Mar 07, 2016 10:53 am
Can you guys provide your nginx error logs from /var/log/nginx/error.log as well as the gunicorn logs in /var/log/gunicorn/alarmdecoder.log and the logs in /opt/alarmdecoder-webapp/instance/logs/info.log - let's see if we got any good information in there. Also, you guys did clear your sessions and cache etc after the upgrade?
Postby JJsLegacy » Mon Mar 07, 2016 11:03 am
I have cleared the cache and tried private browsing and deleting the certs - tried all I can think of.
I will e-mail them to you guys now.
JJsLegacy
PreviousNext
