AlarmDecoder WEB Interface Feature Requests
Postby CF86336 » Tue Oct 20, 2015 10:30 am
Apologies if this topic already exists.
I'd like to suggest a feature for the AlarmDecoder WEB Interface: In the main notifications list, provide a master enable/disable checkbox or equivalent for each notification entry. Reason: We have one zone, a water heater leak detector, that I'd like to have trigger emails and text messages all the time. So I'd like to set up a notification for that one zone. We have about 16 other zones and associated notify-on conditions that I'd like to have trigger emails and text messages when we're away from home for an extended period, but I'd like to be able to quickly enable/disable those.
Also, if it is not already possible, I'd like to be able to specify multiple destination addresses for a given notification, when appropriate, e.g. my and my wife's email and text message addresses. The way I've got it set up now is that I have a separate notification for each address, which are for the most part duplicates of each other except for the destination address.
CF86336
Re: AlarmDecoder WEB Interface Feature Requests
Postby kevin » Tue Oct 20, 2015 10:33 am
With the ability to filter zones from notifications, you should be able to exclude your water zone from most notifications and create a notification just for that specific zone (remove all zones from list except the zone you want to monitor)
But I do see the need/want for enabling and disabling notifications, so this will go on our list
I've not tried, but you can potentially do a comma separated list of emails as the recipient
Postby kevin » Wed Nov 04, 2015 2:51 pm
CF86336 wrote:Apologies if this topic already exists.
Hey there,
So as I am working on these requests, I did test and confirm that on email notifications, multiple recipients is already supported - you just do a comma separated list of emails (up to 255 characters) for the destination field. Due to API's and such, email is the only reliable multi-recipient notification type. If you need text to phone through twilio for example, I suggest making two separate notifications (this is where the below cloning feature will come in handy)
What I have done on our local branches are:
Ability to copy notifications for ease of cloning with minor differences between the two notifications
I am working now on the ability to enable and disable a notification.
Postby CF86336 » Tue Dec 22, 2015 4:17 pm
Thanks. I tried a comma-separated list of email addresses before seeing your reply, and am happy to say it works! Also, I found that emailing to text on a phone on AT&T's network using <phone number>@txt.att.net also seems to work, but I'm not certain it works 100% of the time--need to do more testing. It works in a multi-recipient notification. I would expect that emailing to text on a Verizon phone using <phone number>@vtext.com would also work, but I'm not a Verizon customer at this time.
CF86336
Postby mrvelous01 » Fri Jul 15, 2016 3:55 am
I'd like to expand on what the previous poster's have already asked for regarding disabling notifications. It would be great if there was a single check box on the web interface to disable ALL notifications, whether for a specified amount of time, or until re-enabled. My situations were a little different as I had a contractor working on my home while I was at work and they were constantly going in and out, and another time with a room mate moving in and out, enabling and disabling the alarm several times during the day. It was a bit embarrassing constantly having to check my txts at the office 40-50 times during the day. Thanks for your consideration.
mrvelous01
