AD2pHat won't talk to Vista panel
Postby 4832M5 » Thu Jul 02, 2020 2:32 pm
Hello.
Have a AD2pHAT that will talk with Pi3B but no messages to/from Vista panel
>telnet 127.0.0.1 10000
Trying 127.0.0.1...
Connected to 127.0.0.1.
Escape character is '^]'.
C
!CONFIG>MODE=A&CONFIGBITS=ff04&ADDRESS=18&LRR=N&COM=N&EXP=NNNNN&REL=NNNN&MASK=ffffffff&DEDUPLICATE=N
Output of a screen session
>screen /dev/serial0 11500
!>C
!VER:ffffffff,V2.2a.8.9b-306,TX;RX;SM;VZ;RF;ZX;RE;AU;3X;CG;DD;MF;L2;KE;M2;CB;DS;ER;CR
!>Ademco/DSC Mode A/D (A) :>A
!>Keypad Address (18) :>
!WARNING. Do not enable a module if the physical module exists on the system.
!Zone Expanders Y/N Max allowed: 02
!>expander module #01 ZN 09-16 (N) :>
!>expander module #02 ZN 17-24 (N) :>
!>expander module #03 ZN 25-32 (N) :>
!>expander module #04 ZN 33-40 (N) :>
!>expander module #05 ZN 41-48 (N) :>
!Relay Modules Y/N Max allowed: 04
!>relay module #01 (N) :>
!>relay module #02 (N) :>
!>relay module #03 (N) :>
!>relay module #04 (N) :>
!>Emulate Long Range Radio Y/N: (N) :>
!>Emulate modem COM Y/N: (N) :>
!>Address Filter Mask (ffffffff) :>plicate (N) :>
!>Config Bits (ff04) :>
!Sending.....done
Several forum message indicate that should see the familiar messages such as "****DISARMED**** Ready to Arm" or whatever. Further tried sending some arm key sequences via Screen and Telnet. Got no response as seen from other Alpha panels on alarm system. The last !Sending.....done above is such an attempt
System information
Vista-21iPLTE running firmware 4.1.16
*191 set to [1][0], address 18 enabled, (have Alpha keypads on 16 & 17)
Pi3b running Buster Lite, manual build from AD wiki.
comm via serial0 (ttyAMA0)
LED on A2DpHat is blinking at about 2 to 3 times per second.
NOTE the AD2pHAT came loaded with beta software V2.2a.8.9b-306
Web app always has keyboard in "Please wait...loading"
snippet from log when running web app
NoDeviceError: ('Error opening device at alarm:10000', error(111, 'Connection refused'))
2020-07-01 20:03:26,323 ERROR: Device not found: Error opening device at alarm:10000 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:545]
2020-07-01 20:03:31,327 INFO: Attempting to reconnect to the AlarmDecoder [in /opt/alarmdecoder-webapp/ad2web/decoder.py:541]
2020-07-01 20:03:31,394 WARNING: Open failed: Error opening device at alarm:10000 [in /opt/alarmdecoder-webapp/ad2web/decoder.py:305]
File "/opt/alarmdecoder-webapp/ad2web/decoder.py", line 302, in open
self.device.open(baudrate=self._device_baudrate, no_reader_thread=no_reader_thread)
File "/opt/alarmdecoder/alarmdecoder/decoder.py", line 277, in open
File "/opt/alarmdecoder/alarmdecoder/devices/socket_device.py", line 208, in open
raise NoDeviceError('Error opening device at {0}:{1}'.format(self._host, self._port), err)
thanks for any help.
M.
4832M5
Re: AD2pHat won't talk to Vista panel
Postby 4832M5 » Thu Jul 30, 2020 3:26 pm
Update:
Telnet to device - get normal alarm status. Can send disarm cmds, they are received by Vista alarm (other panels respond).
Keyboard screen just sits in "waiting...."
All other screens/tabs in webapp appear to work as expected.
4832M5
Users browsing this forum: No registered users and 3 guests
