Homebridge Plugin
Homebridge Plugin
Postby aficustree » Sun Jun 11, 2017 7:22 pm
I created a plugin for homebridge that allows you to use alarmdecoder natively in homekit. Using this plugin you can tell Siri to turn on and off your alarm.
https://github.com/aficustree/homebridge-alarmdecoder
Shaun
aficustree
Re: Homebridge Plugin
Postby kevin » Mon Jun 12, 2017 9:21 am
Thanks for the contribution - the more platforms that support us the better!
Site Admin
Site Admin
Postby sarahah » Fri Oct 13, 2017 3:58 am
The plugin looks good. :)
sarahah
Postby aficustree » Sat Dec 09, 2017 2:43 pm
made a new version that exposes all zones as motion or contact sensors https://github.com/aficustree/homebridge-alarmdecoder-platform
aficustree
Postby tommyd75 » Thu Dec 28, 2017 12:15 am
aficustree wrote:made a new version that exposes all zones as motion or contact sensors https://github.com/aficustree/homebridge-alarmdecoder-platform
I started using that new plugin and it works great!
Any chance it would support non burglary devices like smoke detectors and Co detectors?
Currently have it set up to show all my doors, windows, and motions. Originally I had added my smokes and Co det but they came up “non supported” (unless I was doing something wrong.
Sent from my iPhone using Tapatalk
tommyd75
Homebridge Plugin
Postby tommyd75 » Thu Dec 28, 2017 12:16 am
Currently have it set up to show all my doors, windows, and motions. Originally I had added my smokes and Co det but they came up “non supported” (unless I was doing something wrong.)
tommyd75
Postby aficustree » Thu Dec 28, 2017 6:27 am
tommyd75 wrote:Any chance it would support non burglary devices like smoke detectors and Co detectors?
Shouldn't be hard at all. My system doesn't have CO or Fire zones to test but I'd be happy to do up the code in a vacuum and let you see if it works. Let me know if you'd be willing to be a guinea pig.
aficustree
Postby tommyd75 » Thu Dec 28, 2017 9:46 am
Sure!
I’d love to try it.
tommyd75
Postby aficustree » Thu Dec 28, 2017 2:49 pm
You should be able to install by removing the old version and installing the development revision (noted by #development)
npm install -g git+https://github.com/aficustree/homebridge-alarmdecoder-platform#development
aficustree
Postby aficustree » Thu Dec 28, 2017 2:51 pm
Sorry, also note that you must name your zones in the AlarmDecoder WebUI and use one of the keywords 'motion' 'carbon' or 'smoke' in order for it to pickup that it's not a contact sensor and behave accordingly. I've updated the readme.md file to note that too.
aficustree
Return to Code Contributions
