Smartthings: possible refresh solution?
Re: Smartthings: possible refresh solution?
Postby jasonsf » Thu Apr 20, 2017 9:38 pm
I updated the apps. The push notifications work well. Zones update within seconds in smart things. Thanks!
Sent from my SM-G920V using Tapatalk
jasonsf
Postby joyce » Fri Apr 28, 2017 7:45 pm
Yeah, I agree with Kevin.
joyce
Postby Jag4666 » Sat Apr 29, 2017 2:55 pm
Does this update also address the need to reverse the open/closed sensors for the zones in smart things app?
Jag4666
Postby jasonsf » Sat Apr 29, 2017 2:58 pm
Jag4666 wrote:Does this update also address the need to reverse the open/closed sensors for the zones in smart things app?
Yes, you can now set the open/closed value in the setup when you configure the smartapp in the Smarthings development environment.
jasonsf
Postby Jag4666 » Sun Apr 30, 2017 7:46 pm
Anyone getting time out error on testing after installing the update?
Webapp is showing the following:
Device Testing
Opening device ✔
Saving device configuration ⚠ Test timed out.
Keypad communication (Send) ⚠ Test timed out.
Keypad communication (Receive) ✔
Jag4666
Postby kevin » Sun Apr 30, 2017 9:08 pm
Check that your settings didn't change and your wiring didn't come loose.
Site Admin
Site Admin
Postby dman2306 » Mon Jul 17, 2017 4:34 pm
I'm still seeing the refresh behaving pretty slowly (refreshing every minute). What needs to be done to get it to refresh in seconds as people here are describing?
dman2306
Postby jasonsf » Mon Jul 17, 2017 8:17 pm
dman2306 wrote:I'm still seeing the refresh behaving pretty slowly (refreshing every minute). What needs to be done to get it to refresh in seconds as people here are describing?
Make sure you've entered the API endpoint and token correctly. It is also possible that you have to uninstall and reinstall the service manager in the SmartThings IDE to make it update. I don't quite remember.
Jason
jasonsf
Postby kevin » Mon Jul 17, 2017 8:37 pm
Also make sure to follow the extra instructions for setting up the SmartThings notification
Site Admin
Site Admin
Users browsing this forum: ghExF2hfAm, Google [Bot], J5Fbr3HcsB, PjT5bve7wh, rf5kR6bGKL, yT3Hve0nhj and 1 guest
