Smartthings Integration stopped working
Postby dewdropremix » Wed Apr 10, 2019 9:45 pm
Hi
I had my Smartthings integrated with my Ademco Vista 21P using AD2PI. The Smartthings app stopped syncing with Alarmdecoder last week.
I updated all my device handlers and smartapp.
I reinstalled the Alarmdecoder webapp and firmware (2.2a.8.8) on the Raspberry PI. I have installed the Smartapp (Version 2.0.3) and I tried to install the Alarm Decoder service for my Location.
I get the following errors
d7addcab-9edf-4625-9305-cb40d07db275 10:53:50 PM: error armStaySet: Could not find 'armStay' device.
d7addcab-9edf-4625-9305-cb40d07db275 10:53:50 PM: error armAwaySet: Could not find 'armAway' device.
Please help
dewdropremix
Re: Smartthings Integration stopped working
Postby mathewss » Thu Apr 11, 2019 12:32 pm
Likely with all of the changes you made we may be dealing with different problems than you had originally.
If you reset everything did you set your API key again? I am available for tech support over a remote desktop likely a simply way to figure out what is wrong is to let me take a look.
If not please send logs from the AD2PI, Confirm you can ARM/DISARM from the Pi web interface. Next logs from the ST Hub when you arm /disarm will show any activity between the hub and the AD2PI.
403 443 2000 Extension 4 for support.
Postby dewdropremix » Fri Apr 12, 2019 6:41 am
How to enable remote desktop or send the requested logs
dewdropremix
Postby JamesBotch » Tue Apr 16, 2019 8:51 pm
JamesBotch
