AD2PI LED blink codes?
Is there a list of teh "Blink codes" available for the AD2PI board??
I've not been successful in getting my recently purchased board to function properly. Installed the recommended Raspberry Pi image and connected AD2PI to Pi 3. Wired to Ademco Vista 10SE panel and ran setup to change Keypad address to 31. When I run Device testing in teh setup now I'm seeing:
Device Testing
Opening device ✔
Saving device configuration ⚠ Test timed out.
Keypad communication (Send) ⚠ Test timed out.
Keypad communication (Receive) ⚠ Test timed out.
In the past if I retested all would be green checks except the last, Keypad receive only would be timed out. Double checked wiring but other than green and yellow (they match instructions and existing keypad connections).
I've tried using both a Ras Pi B model 2 and newest Ras Pi 3 (hoping increased board Horsepower would help). Earliest tests had the AD2PI LED blink fairly rapidly, more than once a second. Earlier I was seeing a Blink-blink pause and then repeat. When I just checked I now see a Blink-blink-blink pause-repeat. I suspect this blink code will indicate some error troubleshooting tip.
I'm off to reimage the RasPi card with your supplied image just in case something happened with the previous attempts (using win32Diskimager).
Thanks in advance.
Device Testing
Opening device ✔
Thanks in advance.
