Vista-20BAY Keypad configuration
Hello! I just got a AD2PI Network Appliance in the mail today and I am excited to set it up, but having an issue enabling the keypad.
I enter programing mode (Installer code + 8 + 0 + 0), but when I hit # + 1, the 1 does not show up on the screen. If I continue with 9 + 1 it displays "Options", much like you would expect if you had only hit #91.
Is there a trick to entering a 3 digit code?
When I go to https://alarmdecoder.local/setup/test, I see:
I suspect this is due to not yet having enabled Keypad #18.
Thoughts?
Thanks in advance!
Keypad communication (Send) ✘ Check wiring and that the correct keypad address is being used.
Keypad communication (Receive) ⚠ Test timed out.
Thoughts?
Thanks in advance!
