Trying to understand the SW architecture
I'm installing the webapp on a Phidget SBC3 (running Debian) and have some questions about each piece. Am I correct in that gunicorn is the actual web server? Does nginx just provide reverse proxy and SSL?
If that's the case, and if the webapp is password protected, then I don't need nginx because the box is behind another SSL/reverse proxy from a gatekeeper server running Apache.
I got nginx running, but I don't think gunicorn is...
The requirements install get to Babel-2.5.1, downloads, then is "killed". Any idea why?
EDIT:
The gunicorn service doesn't start properly.
I did change the gunicorn user/group to root/root
EDIT:
service gunicorn start
