Smartthings - 1 Sensor not reporting
Recently installed the AD2PI with my Safewatch 3000 and got everything up and running, impressed in how easy it was - not necessarily intuitive but if it isn't a challenge why bother!!!
All of the sensors are reporting to Smartthings, including sensor 1 (it is possible that I have the same problem on a couple of windows I haven't tested but I doubt it), but sensor 1 isn't updating the ST virtual contact. I see it in the ST IDE logs coming in, appears to identify it correctly in the parser, but the virtual contact doesn't update.
The only thing I have done outside of an Out Of Box install is change the ST device handlers and smart app to support up to 12 devices, which is what I have. AND the devices over the typical 8 are reporting and working properly!
Not sure where I should look...
7:28:10 PM: debug --- handler.parse: resulting events=[
[name:lock, value:unlocked, isStateChange:false, displayed:false, linkText:AlarmDecoder, descriptionText:AlarmDecoder lock is unlocked],
[name:armed, value:disarmed, displayed:false, isStateChange:false, linkText:AlarmDecoder, descriptionText:AlarmDecoder armed is disarmed],
[name:alarm, value:off, isStateChange:false, displayed:false, linkText:AlarmDecoder, descriptionText:AlarmDecoder alarm is off],
[name:smoke, value:clear, isStateChange:false, displayed:false, linkText:AlarmDecoder, descriptionText:AlarmDecoder smoke is clear],
[name:panel_state, value:disarmed, isStateChange:false, displayed:false, linkText:AlarmDecoder, descriptionText:AlarmDecoder panelstate is disarmed],
[name:alarmStatus, value:off, isStateChange:true, displayed:false, linkText:AlarmDecoder, descriptionText:AlarmDecoder alarm status is off],
[name:zone-on, value:1, isStateChange:true, displayed:false, linkText:AlarmDecoder, descriptionText:AlarmDecoder zoneon is 1],
[name:zoneStatus1, value:1, displayed:false, isStateChange:true, linkText:AlarmDecoder, descriptionText:AlarmDecoder zone status1 is 1]]
7:28:10 PM: trace --- update_state
7:28:10 PM: trace --- handler.parse: http result=[panel_relay_status:[], panel_bypassed:false, last_message_received:[00000301100000000A--],001,[f72000071001030028020000000000],"FAULT 01 FRONT DOOR ", panel_powered:true, panel_on_battery:false, panel_fire_detected:false, panel_alarming:false, panel_panicked:false, panel_armed:false, panel_armed_stay:false, panel_zones_faulted:[1], panel_type:ADEMCO]
