Managing partitions with the webapp
PostPosted: Thu May 21, 2015 7:30 am
by lucavista
I've a system with multiple partitions. The desktop app handles them flawlessly. The webbapp display loops on all the different partitions breaking the usage. Ideas?
I just saw there is an update that I'm going to try now (an updated raspberry image would be nice!).
Re: Managing partitions with the webapp
PostPosted: Thu May 21, 2015 8:32 am
You can manage what you see by adjusting your address mask in your settings to ignore messages from keypads you don't want to see
New raspbian image coming soon, almost done - pi2 support etc!
PostPosted: Thu May 21, 2015 9:36 am
by lucavista
I tried that without success. I managed to set the mask for filtering panels addresses (with the help of the desktop app) but I don't undestand how to filter partitions.
I was hoping for pi2 support, thanks!
PostPosted: Thu May 21, 2015 9:49 am
You want to set the mask to enable only keypads on the partition you want to listen to
You can figure out the address mask you need from the AlarmDecoder Keypad - just make sure the keypads you want to listen to are the only ones enabled. Once you have the mask, go through setup in your webapp and for the address mask put in this value to listen to only keypads on the partition you want to listen to.
PostPosted: Fri May 22, 2015 9:06 am
by lucavista
In my configuration every keypad can manage every partition. Keypads have a default partition associated but they can switch on others.
I have the same setting in both desktop and web app but different behaviors.
PostPosted: Fri May 22, 2015 9:21 am
WebApp does not currently support this configuration it is in the todo list.
PostPosted: Fri May 22, 2015 9:40 am
by lucavista
Ok good, I though i was missing something since I'm not an expert of these alarm systems.
Thanks again, I'll check the commits. If you need some message dumps let me know!
PostPosted: Fri May 22, 2015 2:30 pm
Just FYI, the Pi2 Image has been released
PostPosted: Mon May 25, 2015 3:03 am
by lucavista
Awesome! Downloading, thanks!
